The Librem 5 features a built-in smartcard reader. While most people use it for GPG I wanted to see if it can be used as an authenticator for services like email (SMTP, IMAP), access to web pages (HTTPS), calendars, etc. without either having to retype a password often or having to store it on the device itself: Single Sign On for all my frequently used services.
For that one can leverage a feature called PKINIT of Kerberos (a network authentication protocol meant to allow secure communication over a non-secure network which uses public key cryptography for initial user authentication (instead of a password). If the key material is saved on the smart card even a lost device can hardly be abused as the smart card is protected by a PIN and will lock itself after three incorrect tries (and you can easily revoke the certificate server side too).
On the service side one can use SASL/GSSAPI to make services like exim, postfix, dovecot, cyrus imapd, apache, nginx or prosodi use Kerberos to authenticate users and there’s many more (like CalDAV servers, etc). The most prominent missing bit for me is currently the Synapse matrix server not supporting GSSAPI yet.
I won’t go into the details of setting up the Kerberos server (KDC) or PKINIT itself or how to configure services as this is already done elsewhere (here and here) but rather focus on the Librem 5 and smart card side.
So for the following let’s assume you have a Kerberos realm called MS20.NIX set up and your KDC has the DNS name kdc.ms20.nix, and your Kerberos principal (your user in the Kerberos database) is called foo@MS20.NIX. You also have an smtp and imap servers called smtp.ms20.nix and imap.ms20.nix set up to authenticate users via Kerberos. Finally we call the CA that signs all your certificates ca.pem (we are following the naming from this).
What follows does look like lots of things need to be done on the command line. I’ll show a simplification at the very end but wanted those bits written down for reference/debugging.
Note that this post is not meant as an exhaustive introduction but more like a quick summary of commands. I’m happy if someone grabs it and adds more details.
Let’s first install the Kerberos client side packages on the phone and test that:
$ sudo apt install heimdal-clients
The krb5-config package will ask for your Kerberos realm, KDC etc. With that in place you should be able to test if you can get a Kerberos ticket via
$ kinit and entering your password.
If that worked the klist output will look something like:
$ klist Ticket cache: FILE:/tmp/krb5cc_1000 Default principal: foo@MS20.NIX Issued Expires Principal Oct 24 12:55:13 2022 Oct 25 12:55:13 2022 krbtgt/MS20.NIX@MS20.NIX
Now that basic authentication worked We’re ready to switch to certificates stored them on the smart card.
Let’s drop the credentials first:
$ kdestroy
I have used an OpenPGP card smartcard and inserted that into the Librem 5. In my case it was salvaged from a Librem Key. As PKINIT uses OpenSC the
OpenSC wiki was very helpful as it has details on how to get key material onto that particular card.
The software to use the Librem 5’s smart card reader is enabled by default as part of the librem5-base package. You just need to add OpenSC to the mix:
$ sudo apt install opensc
With that you should already be able to see the card:
$ opensc-tool -l # Detected readers (pcsc) Nr. Card Features Name 0 Yes L5 built-in SmartCard Reader 00 01 00 00 1 Yes L5 built-in SmartCard Reader 00 01 00 01
As there’s only a single reader and the second entry can confuse opensc let’s ignore that one:
$ cat <<EOF > /etc/opensc/opensc.conf
app default {
ignored_readers = "TTXS serial 00 01 00 01","L5 built-in SmartCard Reader 00 01 00 01"
EOFWhich should make the output look like
With the reader up and running we can now store the certificate and private key on it. For simplicity we create these on the KDC and transfer them to the phone
(a more realistic setup would create those locally and use a certificate signing request so the private key never leaves your hands):
On the KDC:
$ hxtool issue-certificate --ca-certificate=FILE:krbca.pem --generate-key=rsa --key-bits=2048 --type="pkinit-client" --pk-init-principal="foo@MS20.NIX" --subject="uid=foo,DC=ms20,DC=nix" --certificate="FILE:user.pem"
Then you’d copy the file to your phone and install certificate and private key on the smartcard like (this will delete any already existing keys on the card):
$ # Install needed packages $ sudo apt install opensc wipe $ # Delete old keys and install certificate and private key on smartcard $ pkcs15-init --delete-objects privkey,pubkey,cert --id 1 --auth-id 3 $ pkcs15-init --delete-objects privkey,pubkey,cert --id 2 --auth-id 3 $ pkcs15-init --delete-objects privkey,pubkey,cert --id 3 --store-private-key user.pem --store-certificate user.pem --id 3 --auth-id 3 $ # Wipe the file containing the private key $ wipe user.pem
Afterward we can look at what’s on the card
$ pkcs15-tool -D Using reader with a card: L5 built-in SmartCard Reader 00 01 00 00 PKCS#15 Card [OpenPGP card]: Version : 0 Serial number : <serial number> Manufacturer ID: ZeitControl Language : de Flags : PRN generation, EID compliant PIN [User PIN] Object Flags : [0x03], private, modifiable Auth ID : 03 ID : 02 Flags : [0x13], case-sensitive, local, initialized Length : min_len:6, max_len:64, stored_len:64 Pad char : 0x00 Reference : 2 (0x02) Type : UTF-8 Path : 3f00 Tries left : 3 PIN [User PIN (sig)] Object Flags : [0x03], private, modifiable Auth ID : 03 ID : 01 Flags : [0x13], case-sensitive, local, initialized Length : min_len:6, max_len:64, stored_len:64 Pad char : 0x00 Reference : 1 (0x01) Type : UTF-8 Path : 3f00 Tries left : 3 PIN [Admin PIN] Object Flags : [0x03], private, modifiable ID : 03 Flags : [0x9B], case-sensitive, local, unblock-disabled, initialized, soPin Length : min_len:8, max_len:64, stored_len:64 Pad char : 0x00 Reference : 3 (0x03) Type : UTF-8 Path : 3f00 Tries left : 3 Private RSA Key [Authentication key] Object Flags : [0x03], private, modifiable Usage : [0x222], decrypt, unwrap, nonRepudiation Access Flags : [0x1D], sensitive, alwaysSensitive, neverExtract, local Algo_refs : 0 ModLength : 2048 Key ref : 2 (0x02) Native : yes Auth ID : 02 ID : 03 MD:guid : 135c302c-ddad-1a3c-f558-8beae7612f9f Public RSA Key [Authentication key] Object Flags : [0x02], modifiable Usage : [0x51], encrypt, wrap, verify Access Flags : [0x02], extract ModLength : 2048 Key ref : 0 (0x00) Native : no Path : a401 ID : 03 X.509 Certificate [Cardholder certificate] Object Flags : [0x00] Authority : no Path : 3f007f21 ID : 03 Encoded serial : <serial>
The OpenPGP card’s default admin PIN is 12345678 and the user pin 123456.
Now add [libdefaults] to your
pkinit_anchors = FILE:/etc/ssl/certs/ca.pem/etc/krb5.conf and place the ca.pem in /etc/ssl/certs.
With that you should be able to use pkinit. The -C option tells kinit to use your smart card for the crypto:
$ kinit -C PKCS11:/usr/lib/aarch64-linux-gnu/pkcs11/onepin-opensc-pkcs11.so foo@MS20.NET PIN code for L5 built-in SmartCard Reader 00 01 00 00:
After entering the pin and typing klist the output should be similar to the klist output above. If you connect to various Kerberized services in your
realm (e.g. by sending mail) the list will grow without having to retype any PINs or passwords:
$ klist Credentials cache: FILE:/tmp/krb5cc_1000 Principal: foo@ms20.nix
Oct 24 12:55:13 2022 Oct 25 12:55:13 2022 krbtgt/MS20.NIX@MS20.NIX Oct 24 12:55:57 2022 Oct 25 12:55:13 2022 imap/imap.ms20.nix@ Oct 24 12:57:45 2022 Oct 25 12:55:13 2022 smtp/smtp.ms20.nix@ Oct 24 13:00:32 2022 Oct 25 12:55:13 2022 HTTP/http.ms20.nix@
The above is very command line heavy and thus hard to use on a phone. With krb5-auth-dialog things become easier to set up. There’s no need to adjust /etc/krb5.conf or to copy any certificates. PKINIT via smartcard is being enabled by a single click and you can select your CA (KDC trust anchor) via UI too:
There’s a graphical dialog to enter your PIN that can either be started via the menu or triggered via a simple DBus call:
$ gdbus call -e -d org.gnome.KrbAuthDialog -o /org/gnome/KrbAuthDialog -m org.gnome.KrbAuthDialog.acquireTgt ''
and the good part is that it won’t prompt you if you already have a valid ticket. So you can e.g. add this as a hook to your offlineimap config.
As far as I know there’s no end user friendly tool to transfer the certificates to the smartcard yet but note that this doesn’t even have to happen on the phone itself. You can provision those elsewhere and then add the card to the phone but it might make sense to add that functionality to either krb5-auth-dialog or seahorse.
I hope this post motivates people to try this out and to leverage Kerberos for authenticating to services via the Librem 5’s built-in smartcard reader.
If you get errors like:
kinit: krb5_get_init_creds_opt_set_pkinit: Failed to init cert certs: Failed to init PKCS11 slot 0
Then make sure gpg-agent didn’t grab the card (e.g. because you ran gpg --card-status).
If Firefox won’t authenticate to your server make sure you’ve set negotiate.auth.trusted-uris in about:config
The original post was published on Colors of Noise, here.
