My trusty laptop’s speakers gave up the ghost. I don’t like to sit around in headphones all the time, I don’t have any other speakers, and the replacements are still being manhandled by the postman.
I’d get used to the austerity if I hadn’t started missing calls from a friend. That’s unacceptable! But what am I supposed to do? Buy extra gadgets just to throw them away after a week? Nope, I’m not that kind of a person.
But hey – I have a Librem 5! It has a speaker. It’s open. I have control over it, and I’m a hacker too. So I should be able to come up with a hack to turn it into a speaker for my laptop, right?
Pulseaudio to the rescue. I look through the guide. There it is: forwarding audio over a network.
I diligently connect both my laptop and my phone to the same network. The guide doesn’t make it abundantly clear, but the phone needs to open its audio service to the external world using the paprefs tool.
Sadly, paprefs is not adapted to a phone screen size, so I spend a moment to check the IP address of the phone, and I log in remotely:
$ ssh purism@10.42.0.185 -X
Last login: Fri Sep 24 14:22:44 2021 from 10.42.0.1
purism@pureos:~$ GDK_BACKEND=x11 paprefsI check the boxes to enable access to sound devices:
I haven’t found any way to make it effective immediately, so I reboot the phone.
Finally, the phone is on again. I check its address again (it’s the same), and enter the magical formula on my laptop:
scp purism@10.42.0.185:./.config/pulse/cookie /tmp/pulse-l5
pacmd load-module module-tunnel-sink server=10.42.0.185 cookie=/tmp/pulse-l5I open pavucontrol to switch the default output device, and here we go! Now sounds from my laptop play on my phone.
Keep in mind that it’s not very efficient. Your network will immediately get flooded with 200KiB/s of uncompressed sound, even if you’re not playing anything. Or at least mine did. It’s pretty bad over WiFi, so I connected my phone and my laptop directly over USB. It’s easy to set up with the Plasma network applet: configure a shared network on the laptop, and then connect the USB cable. The phone will take care of it automatically.
